Got a 225hp ox66 2000. Should the oil level in the tank mounted on the motor be at the top mark or does it go up and down between the high and low level marks? My alarm is going on and off and motor is cool to touch on the heads so I am assuming oil level is the alarm. My oil level is right on the low level mark, could I pull the sensor up a little to see if it fills? how long should it take to fill? Have not had time to look at it but will start this weekend with filters. Need to know how to check the oil pump from remote tank. Had motor 5 years now all good, o2 sensor clean -new water pump and thermostats-cleaned vst filter.
