After browsing through the forum, I couldn't find any information that helps me figure out what's wrong.
Anyways,I have a 360b in my trojan I was out on the water the other day and had the boat in nuetral. I rev'd it up a bit and brought it back to idle.
All of a sudden a black substance started coming out of the exhaust and into the river. I check the oil and it was reading right
at the add line. I added a half quart and limped it back to the dock. When I arrived back at the dock I checked the oil and it didn't register any less. I started the boat again and let it idle and no signs of anything coming out.
However, as soon as I rev'd it up and brought it back to idle, the oily substance came out again.
The fluid is black but it's not sitting in the water like normal oil - its more grouped together with circles.
The color is a dark greyish black. When I put my hand in it smelt like oil. I changed my oil about 7 weeks ago and haven't ran it an excessive amount.
There is no oil leaking inside the hull, only out of the exhaust into the water. I checked the oil the following day and it did read a quart lower; however the engine was cold.
Can anyone provide any advise that will help diagnose the problem?
Keep in mind while your providing advise that I'm a newbie with engines but I'm looking to learn and detai
l info will be extremely helpful. I truly appreciate any help! Thanks in advance for your time.
