Oil leaking from small pin holes
turkey4545
Help please. I had started my
Help please. I had started my 98 25 hp Evenrude for the first tonight in a while. I had it hooked up to the garden hose working on the kill switch which was giving me problems got that fixed. I then rasied the motor to look at the prop when I noticed black oil running out the upper small pin hole in the lowwer unit. I opened the drain hole on the lower unit and it looked the same. Anyone have an idea of what might be the problem. Thanks from Tennessee.
this could be an exaust extra
this could be an exaust extra oil mixed with some gas that didnt burn. thats the most common thing i see coming from the lower unit. check the oil in the lower unit if milky change and if the lower unit is actually leakin it istime to re seal it
