Oil leak
"have an oil leak from behind
"have an oil leak from behind the crank pully, there appears to be some sort of cover there whats behind this is it a pully, gear of timing chain, the engine is a 3ltr lx . its a drop every 5 min . any picks would be helpfull thanks in advance"
id say that the seal on that c
id say that the seal on that cover is going bad the one that the crank comes thru have you had the boat out or just starting the season if your just starting the season it may have dried a bit over the winter and it may stop. and a drop every five min is a very minor leak but we are talking about a seal and it could get worse fast
"I'd have to say that it&#
"I'd have to say that it's most likely the dampner seal on the timing cover(#15 on the diagram), If you have room (about 6-8") you should be able to do it without taking the engine out, at least lift the front up. You will need to suspend the engine at the front and remove the front mount, but DO NOT TOUCH the bolts and nuts immediately in front of the water pump these adjust the angle of the engine, ONLY remove the bolts on sides and the 2 at the bottom.
The seal can be removed without taking the timing cover off but you will need a puller for the Dampner. If you cant do it that way or you want to replace the timing cover gaskets, you'll need to pull the engine as the pan will need to come off to do it right, but there are ways around that. ( i did it today on my inline 6 ) very close to the 2.5L and 3.0L
The seal and gaskets are also the same as my engine which is the same as a 70's and 80's GM 4.1L 250ci Engine available at any parts store.
MarineEngine.com has them too.."
have had it in the water twice
have had it in the water twice it was out of the water for 18 months before that. i have a container under the leak now so i am going to see how much she is leaking in a day after that will have to remove the leg to get a better look guys thanks for your feed back
Clean the oily area of the lea
Clean the oily area of the leak and add some oil dye leak detector and run the engine for 20 mins. That will isolate the leak.
