Oil Leak near prop
geoff
I've got an oil leak righ
I've got an oil leak right near the prop on my lower unit. Is there a seal that has possibly gone bad?
fishing string probably caugh
fishing string probably caught in the prop. seal at end of shaft before the prop.
" I had same probem- replaced
" I had same probem- replaced seals, but need to know the trick to stabbing hub back in lower unit to mesh with gears..doesnt seem to be going in as far as it should.. "
