"I had to jump into this one.
This is a copy of information that I emailed to James Taylor privately a couple of days ago.
"I have only ever used Merc filters, and I would recommend you do the same, for the minor price difference. I cut the first one from my 6.2 open after breakin this season (to look for metal bits and other debris) and I can tell you that they are built differently than a standard auto oil filter.
The filter media is a 3 layer material with a very fine satin-like outer layer that will collect more smaller particles than a standard auto single layer cardboard media.
I figure that oil and filters are pretty cheap compared to most other boating expenses, so why not use what is recommended?
By the way, if yours is a top mounted filter, the easy way to drain it is to drive a nail hole or two thru the top right after you pull the sump drain plug.
Then after 15 minutes or so the filter will be empty and you can unscrew it with minimal mess. Otherwise you will have oil everywhere."
Just my thoughts.
Rod"
