"Likely an easy question; I h
"Likely an easy question; I have a slight leak coming from the oil filter around the rubber gasket, on both engines (M440). I thought this would go away when I changed the oil/filter (Baldwin). But has started again with the change (both engines again). I did put oil on the rubber seal and the filter is on hand tight. Anyone else experience this? Hints, suggestions, anecdotes?
Thanks"
Thanks"
