rod_stewart
Outstanding Contributor
Does anyone cut apart their used oil filters and inpsect the pleats for metal fragments and other "stuff"? I picked up this idea from an aircraft engine mechanic friend.
I do this about every second oil change, just to see that the engine is not self-destructing.
It's easy to do with an air hammer; just cut the can apart at the lower seam, then cut the pleats top an bottom with a sharp knife, and stretch them out flat. Using a bright light it's easy to see if there are any shiny metal particles hiding in the pleats, or anything else that shoudn't be there.
Not surprisingly, my first filter inspection on a new remanufactured 6.2 MPI turned up quite a bit of interesting stuff, but basically nothing since then.
Anyone else do this?
Rod
Rod
