Oil drain hose
bpiper
"I Have a newbie question , th
"I Have a newbie question , the oil drain hose in the bottom of my boat, '87 175 mercruiser,do you need a pump to get oil to drain out of this hose or do you just open the end?
thanks"
"Pull it thru the transom, rem
"Pull it thru the transom, remove the plug and let it drain; drains best with hot oil and loosening the oil fill cap on the valve cover."
