Oil cooler lines
kevincave
where would be a good place to
where would be a good place to get oil cooler lines? 7.4 inboard motor with cooler in the water line...
"my oil cooler doesnt have the
"my oil cooler doesnt have the adapter, they are run directly into the block. and there is only 2 of them. directly from the cooler to block. on a big block race car i bought fittings(which i have) and bought high pressure line. long time ago but dont remember ever having problems.."
"Perhaps if you had posted you
"Perhaps if you had posted your Volvo Penta model and year I could have provided you with a better schematic. Unfortunately, I am just shooting in the dark based on the scarce information you have provided. Anyway, I'll try again:
Is this one your set-up?
http://www.volvopentastore.com/COOLING_SYSTEM_WITH_HEAT_EXCHANGER/dm/cart_id.963 744532--session_id.509487656--store_id.366--view_id.325781
or this?
http://www.volvopentastore.com/COOLING_SYSTEM/dm/cart_id.963744532--session_id.5 09487656--store_id.366--view_id.325713
or this?
http://www.volvopentastore.com/COOLING_SYSTEM_WITHOUT_HEAT_EXCHANGER/dm/cart_id. 963744532--session_id.509487656--store_id.366--view_id.325657
maybe this?
http://www.volvopentastore.com/LUBRICATING_SYSTEM_740B/dm/cart_id.963744532--ses sion_id.509487656--store_id.366--view_id.314252
or this?
http://www.volvopentastore.com/LUBRICATING_SYSTEM/dm/cart_id.963744532--session_ id.509487656--store_id.366--view_id.325799
Hopefully, one of the above schematics will work your you.
Good luck."
"sorry bout that i just though
"sorry bout that i just thought if someone knew of a place to get oil lines made. the boat is a 76 searay 7.4 290 outdrive. your first schematic is the one i believe that was originaly installed in my boat. it has a later model engine in which i am sure now after looking at that schematic, the hoses were adapted to the oil cooler fittings on the block. i think i could use a couple of the hoses pictured in that schematic.. thanks for the help. i will use that schematic and have something to go for ...kc"
