As you can read from my last post, I lost all the oil as a result of engine failure---huge mess a couple weeks ago. I disconnected the fuse for my auto bilge, bought some oil absorb pads ($1 each, about 20" square), and two gallons of Purple Power from O'Reilly's. I placed the oil absorb pads to skim the oil off the top on the minimal bilge water---they absorb the oil, not the water. There was a lot of oil accumulated in the forward compartments where I cannot reach, I could only see it with a flashlight. I took a hose and agitated the oil forward on top of the water and would place the oil absorb pads as it collected towards me in an area I had better access to. After all the oil was collected, I then diluted the purple power about 30% with water in a spray bottle and sprayed down the residue marks and wiped up with blue shop towels. I then rinsed everything with the hose and then sucked it out with a hand bilge pump into a five gallon bucket. Remember to hook the bilges back up!
I never would have thought of agitating the oil with water until I saw a program on Nat Geo Channel called "Salvage Code Red". They rescue stricken vessels and the first thing they have to due is pump oil out of the bilge/engine room.....
