I had just drain (actually sucked out my oil) and poured in a new 5 qt. I then went to remove my oil filter and had forgotten it was a remote filter located up high at the front of the engine. This is much more convenient than my old boat but when I unscrewed the lid I heard a sucking noise and I quickly realized what I had done. I had just drained a quantity of old dirty oil into my new clean oil. My crankcase was now also over filled. Lesson learned, do things in the right order. I could have probably just sucked out enough oil to until the dip stick read correctly but it bugged me to have mixed dirty and clean plus I wanted to know just how much oile was in the filter housing and hoses. I removed six qts of oil.
This made me wonder if it is onto drain and refill with the total capacity (engine plus filter) because initially when the engine starts, the oil filter will not have any oil in it and the the oil pan will be a qt high. So my question is does the 1 qt "overfill", that would only last for a minute until the filer was filled, matter? Or would it be better to fill with 4 qt, start the engine and then add the final qt?
Sorry for the typos, somehow my iPad won't let me go back and edit. I think you can get the drift though.
