Oil buzz problem
jjdluz
"1992 yamaha 200 outboard,take
"1992 yamaha 200 outboard,take out fishing run great,on the way back,the oil buzz went off,after that cant go over 1800 rpm,if i try it will make wong sound,and i bring it back on land and run it,it will become normal if the battery switch is on 1 or 2,but as soon i turn the battery switch to off while motor still running,then oil buzz will go off again,and it wont go over 1800 rpm,help with tips,thanks."
"thanks for the warning,and wh
"thanks for the warning,and why,i like to know more,and i alreaDY USE PREMIX OIL AND GAS,what can i do to stop that oil alarm buzzer go off,so motor wont go to safe mode,thanks so much u helping out everybody,u are a great guy and mechanic,"
first u need to c if it is the
first u need to c if it is the overheat or the oil sensor
most guys just ziptie the sensor to read full
"i belive is oil sensor,first
"i belive is oil sensor,first the oil alarm light is blinking,and i use laser temp gun check the head cylinder temp it is under 100 deg the whole time,it is cool,also i unplug t-sta one at the time wont stop the buzzer,and like to ask u ,u think that will solve the problem i have,hope is nothing else, and the oil sensor need to ziptie is located at the tank on the motor,right?thanks for all the life saving tips."
there are 2 senders
one on en
there are 2 senders
one on engine
one in boat
the one on the engine tells the boat tank to pump
"thanks,i will give it a shoot
"thanks,i will give it a shoot,ziptie the sensor on motor see what happen hope the buzzer will go away."
