Akums razor,
"The simplest explanation is usually the best". When one detects water in the crankcase oil the T-stat is the easiest to fix and the next easiest is the oil drain plug.The metal gasket on the drain plug will fall off the plug when you remove the oil always be sure that the gasket is in place when you replace the plug.
Just a thought.
Just a thought.
