Oil amp gas mix
bw94
"I have a 70hp(model #TE70
"I have a 70hp(model #TE70TLCE).Is was wondering if someone knows the mix ratio for the gas and oil,and also what oil should i use. And on the lower unit, I need to change out the gear oil. but I don't know the capacity. please help, thanks"
"Somewhere around here? I thin
"Somewhere around here? I think I remember seeing a chart that showed various size motors and what the average capacity of the lower was...
In reality, why do you need it? Just pump in till it comes out the vent... No real reason to know the actual capacity unless you suspect something is amiss?"
