"I have a 2002 200 HP Yamaha h
"I have a 2002 200 HP Yamaha hpdi, and after the engine is warmed up and only on an idle, the alarm comes on. After shutting the motor down for about 5 to 10 minutes and starting it back up again, the alarm goes off. It doesn't come on when running the engine for a long time or on higher RPM's, only on an idle.
I recently put in a water pump propeller kit and the engine is "peeing" water on an idle, and pees harder with more RPM's. But, I was wondering if maybe a seal in the water pump kit might have come out of place after installing the new water pump kit?
My remote reservoir was full when the alarm went off and there was also oil in the mounted oil reserve area at the side of the engine. The engine is also peeing water. I'm not sure what the likely problem is.
Please let me know if you have had a similar problem and what you found the problem to be, or if you have any suggestions.
Thanks,
Rick"
Thanks,
Rick"
