Bruce Honnigford
I have a '71 Merc 650 outboard ser #3155373. This is a 4 cylinder unit.
My research has pointed my starting problem to a bad trigger. This may have been caused by removing the battery from a running engine resulting in the engine firing only when the starter is engaged. I am overhauling the engine and have it partially disassembled at the moment.
While shopping for a replacement trigger for 332-4177A3, I purchased a similar old new stock 393-2918a6 which is the wrong part due to bad catalog data.
Recently I found an old/new stock ignition replacement kit 393-3736A78 that includes a newer version 393-3736A79 trigger which should be the correct part for the 650.
So I have 3 triggers: One suspected bad and 2 suspected good.
Before installing the "good"one, I would like to verify if the unit ohms out correctly and compare it to the other 2 for reference.
All the triggers have 3 wires - BLK, BRN and WHT.
I have no schematic of the internal circuit and no specification on the resistance values for the wiring.
If anyone can supply this information I would certainly appreciate it.
