Like Don said, this is separate from any other existing inverter/charger so that doesn't factor in.
The "good " setups have a regulator, I've seen a couple put in w/o any regulator and it can destroy a battery bank in a short time given a sunny summer.
Only concern I'd have is to make sure the regulator is compatible with the battery chemistry you wanna connect it to. Gel cells, in particular, are charge voltage sensitive.
The other key to making it work is to select a solar source with enough AH capacity to replenish the energy you'll consume...maybe the industry has standardized a rating procedure but I'd not hold my breadth.
