I have a 1999 Bayliner 2855 wi
I have a 1999 Bayliner 2855 with a 7.4 I was told that the manifolds are leaking and caused the bolts to rust out. Labor would be about 8 hours to cut the bolt heads off and install new manifolds. Is this the only way to get the manifolds off? Also should I go aftermarket or OEM. Are aftermarket manifolds as good as OEM?
Thanks Mike
Thanks Mike
