R
RobCutlip
Guest
" I took my boat to the lake y
" I took my boat to the lake yesterday (the first time in 2 yrs) and it started right up and idled great! It's a 'no wake' lake but I did try to throttle up for a second and the motor started to bog and would quit if I didn't back off. I went to the local repair shop to purchase rebuild parts for the carbs (3 cyl w/3 carbs). Last night I put in new needles/seats, gaskets, and cleaned everything with carb cleaner. I took out the jet in the bottom of the float bowls and sure enough they all had a little crud in them. I took the boat out today and again it fired right up. Today the idle was a little more erratic and after idling for 20-30 minutes, the motor really started acting crazy. It would jump from a rough 1200rpm to about 1800 rpm and then go back and forth several times. Today when I gave it throttle it would still bog, only this time I would 'tap' the choke switch and it would speed right up and smoothly. Also, with the boat in neutral, if I move the start lever(high idle)up the motor would rev up to about 5000rpms! I had to apply the choke to get it down or turn of the key.
The longer I was out the worse the boat ran. I have good spark on all 3 cylinders and I know the carbs are clean. What else could be causing this? Coil, stator, rectifier? I have no idea.
The motor is a 60hp by the way, model # 60-ESL71c. Thanks in advance. Rob "
