saltlife321
"I posted an ad about this pro
"I posted an ad about this problem before and I have done several things to the motor since. Its a 94' 200 ocean pro. The motor starts up fine and runs well till it warms up, then during neutral idle it seems to load up and starts to bellow white smoke out of the exhaust. If I don't increase throttle the motor seems to bog out and shut off. I have pulled the heads and checked for water in the cylinders and have pulled the intake cover and inspected the carbs. Replaced fuel source with a secondary tank. And have replaced the water/fuel filter. New plugs and wires. The smoke smells like two stroke and there seems to be a lot of fuel residue(gray film) in the prop hub. Compression is 105 psi on all cylinders. Someone before mentioned that I should check the vacuum lines that clean out the old fuel from the cylinders but I'm concerned that its something else due to the amount of smoke coming from the engine. The smoke will thin out after holding the motor at about 1800 rpms, but quickly loads back up and shuts off. Any tips or suggestions would be greatly appreciated as I cannot afford to take my motor to the shop. Sorry for the story. Thanks P.s. Oil injection has been disconnected."
