Hi Boaters. I recently got a 1989 Bayliner Baretta 17ft. open bow with a AQ131D and 275 drive. It sat for at least 10 yrs. before I got it. I oiled the cylinders and hand cranked it for a few day. Things seemed to be ok. Changed the oil and gave it fresh gas. Put a battery on it and gave it a try. So it turned over but stopped almost immediately. Discovered the timing belt broke. So i removed the heat ex-changer and other things to get to the belt. Spring and tension wheel were find. No play there. Removed the raw water pump. Will rebuild that as the boat came with a kit. The cross piece behind the raw water pump was broken so will replace that. So was going to put all back into timing positions. The cam gear kind of snaps to 4 position when turning. This must be normal for compressing the valve springs, right? The middle gear which turns the distributor turns freely and lines up fine. The lower crank timing gear I can't get to it's mark as the crank only turn about 3/4 of a rotation and hits something. Pulled the plugs and found something in the #4 cylinder blocking the rotation and it looks like ash everywhere on top of the piston. Sorry for the long story. I was hoping someone could help identify the piece in the cylinder from the pics. Also I think this in a non-interference motor so I don't think the piston would have hit a valve. Could a stuck valve break somehow? I'm confused because it turned freely when I was hand cranking the engine. Thanks for looking, Matt
