F
Frank MacKay
Guest
Just reinstalled my alpha i Ge
Just reinstalled my alpha i Gen i sterndrive after changing the gimbal bearing and bellows. and I just realized that I put and o- ring in the wrong place. There's two that go on by the knuckle joint (U-joint) and another on the other side of the bearing as the spline enters the engine. I put that one on the end of the drive shaft as i shoved the stern drive back together so now its on the same side as the other two. Do you think there may be problem there?
