Hi everyone, thanks for reading
I have a 8hp nissan 2 stroke, and after having lack of power issues have found a suspect problem. If i take off the spark plug wire on on plug, the motor changes rpm but it still keep running strong, when i take off the spark plug wire from the other one it runs sloppy and then stalls. So i have spark in both and the run but one is off maybe the spark I am thinking, just learning here about outboards ..
Thinks i have tried
1. switching spark plugs
2 switching spark plug boots
3. checking compression - it's the same and within spec
I can see anywhere that there is two coils to swap to check on this unit it seems like one big unit, i also don't think you can change the spark plug leads without replacing the whole thing, does this sound like a ignition coil problem to you ? and do these come as one unit or something ?
Thanks !
Pat
Thinks i have tried
Thanks !
Pat
