Hey Johnson/Evinrude Forum!,
I am a brand new boat owner and I am quite happy after much consideration and research to join the Johnson family. I bought a 1997 Stratos 2100 Center Console 21 feet with a 1997 Johnson Oceanrunner (carburetor) V6, 2-stroke model J200RXEUA. The serial number is G04307436.
The reason for this post is simply for beginner's information on boat troubleshooting and maintenance procedures. I bought a manual from ( http://www.selocmarine.com/product_f...hp?Engine=3565 ) to guide me through periodic inspections, maintenance, rebuilding and recommended hardware for my motor. Although this printed manual is great for beginners, intermediate, and expert boat owners, I still have some questions and concerns for both my boat and motor. I hope to receive as much feedback and knowledge from the Johnson/Evinrude Community.
My intentions for owning my boat are for lake activities and offshore fishing adventures.
First;
I am currently located in the Midwest and winters can be rather harsh. Due to the extreme cold I winterized my boat. I executed these following procedures and would really appreciate some feedback whether I did this correctly, incorrectly, or simply did more than what i should of. My boat is located in outside storage, not in a climate-controlled indoor storage unit.
1. Pumped out the old lower control gear-case oil with brand new fresh gear-case oil recommended by the Seloc manual specific to my motor.
2. Replaced all 6 spark plugs with brand new Champion spark plugs. Recommended by the Seloc manual specific to my motor.
3. Ran anti-freeze through the ear muffs and circulated it through my engine. (Used the pink stuff) Rv/Boat Anti-freeze.
4. Fogged the cylinders with the motor running (circulating anti-freeze) until the motor shut off.
5. Disconnected the main fuel line to the motor.
6. Cleaned and waxed the boat prior to storage.
7. Sprayed clear coat 3 times on my trailer to prevent rust and oxidation.
8. Removed all batteries and currently trickle charging them with battery tenders.
I dumped a whole can of Sea Foam in 3/4 of a tank in my boat during a lake day prior to winterizing it. Therefore I did not pour in any Stabil.
Were my procedures correct? Did I miss any steps to safeguard my motor and boat for next time's use? Did I over do it?
*Another question I have for the Forum pertains to my boat. I have trouble locating my livewell but i am pretty sure it is located just forward of my center console. Can anyone inform me whether my boat actually has a livewell? Or do i need to modify it and install one?
*How do I go about testing my Bilge Pump? The one time i took it to the lake after spending more than 5-6 hours on the water, I flipped up my switches and never saw any water pour out of the sides. Is there a way to actually test the pump by filling water inside the boat? Or do i need to check for continuity and proper cable connections for the pump?
*My boat has a fuel/water separator installed. Do I need to buy one specific to my engine? (Johnson Model), or does any brand work fine? I know plastic/aluminum is preferred on marine engines, how often should those be replaced?
*Last but not least, what are the proper steps to get my boat up and running again as soon as the winter is over?
Thank you again for all your consideration, time, and effort to teaching me and enlightening me with your knowledge! Hope to hear from you guys soon.
First;
