yooperboater
I just replaced the water pump on my 1996 25 Hp tiller electric start Evinrude and have two issues that I would appreciate comments on.
Thanks for any comments
Yooper Boater
- The reason I replaced the water pump water that no coming water was coming out of the hose off he cooling chamber on the engine. My old water pump impeller was shot, but now with the new pump I'm still not getting water out of the hose. The hose s not plugged. Should I be replacing the thermostat next?
- After re-connecting the upper and lower gear shifter rods I can only get reverse to engage. When I shift to the neutral position it is still engagd in reverse. When I shift to the forward position it is not engaged at all.
Yooper Boater
