Good day folks, this is my first time even posting a question. *So have patience if I suck! * Lol
I got a 40 hp mariner (40 E * *6E95 * *104752), not sure of year (chances are mid-late 80's) 2 cylinder. *Excellent compression (120 per hole), and fires right up after 1 or 2 pulls. *The issue lies in achieving any higher than 1/3 of the rpm's of w.o.t. *This only happens when it's in gear in the water. However, that being said i get a slight few more rpms if i open the choke as im going. *When in neutral, she'll rev up as high as you want it to. *She idle's fine with the choke on, but doesn't idle while choke is closed. *
In respect to what i've done with it (as in trying to get to the root of the problem) i hought i was losing spark. *so, i started it at night (seen nothing) and tested to see if there was spark the old fashion way. *lol. *So, i tried changing the coil ( because i have an extra). *I'm not sure about in forward (because I never had her in the water since) but for the rest it's the same (I.e. I get a shock from the top spark plug boot only but a bit less, she still fires up real quick, and to be honest it sounds pretty good).
so, where should I start, I'm somewhat knowledged of these (been on the water recreationally/commercially for 25 years) but I ain't no tech. *
I appreciate any help I can get.
thanks guys*
robby
thanks guys*
robby
