not peeing
plusxman
i have a 30 mariner 1990,changed the impeller and the thermostat.put the ears on bottom end it peed a bit then sputterd then steam then peed again with the preasure of the water hose. then i used a garbage can and got nothing,except hot air, going out of my mind ,used compressed air on all the holes made sure everything was clear,rcan not figure it out:mad:
Revisit the impeller work...gaskets and plate may be installed wrong. Verify the water tube top end is seated properly.
thanks for replying went to yamaha dealer and bought a new impeller the aholes at mercury sold me the wrong impeller motor works fine now
