1973 Browning Marine
At the beginning of season, posted about an impact I had doing a stupid water test on a local river. (What a hell hole that turned out to be!) Anyway, knocked a hole in lower unit case and limped back to dock. Bought another used lower, installed new water impeller kit with housing, reinstalled, etc.,etc. Started boat on a hose setup and after about 10 minutes I looked at the gauge and it was pegged at 250 degrees. I stated all of this stuff on my initial post and have not had time to follow up on it until today. (never really got in the water this season except for the stupid water test!) My concern is that I cooked the thermostat when I overheated. What do you guys think? Would those temps. possibly cause the thermostat to fail. This is what it has been doing intermittantly on the trailer since I have had this problem:
1) I ran engine probably ten times since installation of lower and the gauge slowly creeps up short of 200 degrees. Sometimes it stays at around that temp. And then occasionally, the needle will drop ever so slowly back to around 180 degrees. One time, when I started engine, it climbed just short of 200 and then shot down to like 160-165.
2) It seems like when I give the engine a little throttle, the temps. come down from like 195 degrees down to say 180 degrees.
3) I also found a piece of impellar in the heat exchanger cold water supply side which makes sense. I had problems with the used drive that I had purchased with respect to the water impellar. Stated that it had a new impellar with the used lower unit. (Alpha One Generation One drive and 1988 3.7lx 180 hp) When the accident happened, there was not any overheat issues. The engine did not overheat until I installed the replacement drive with a so called new impellar. Anyway, I trusted the guy and got screwed on initial startup on trailer. The engine at this point overheated immediately and reached 250 degrees. Changed impellar and housing and I am still running awful hot especially considering there is no load on engine on trailer and it will run even hotter in the water.
4) I have ordered a new 160 degrees thermostat and have not removed thermostat housing yet. I was wondering if it is possible for impeller debris to reach the thermostat housing and possibly hold the thermostat closed. Or worse, I simply cooked thermostat and it is now only partially opening. Make sense? I am planning on doing a full service: oil,filters,etc. before taking boat out for the rest of the striper fishing season but cannot do so until I am convinced that the boat will not break down. It never ran at these temps. on the trailer before the incident so I have to try and hopefully eliminate this problem.
5) I also had the 4 inch heat exchanger cleaned and just reinstalled today. Also noticed that impellar is delivering a good supply of raw water to the exchanger at this point.
I gave you guys as much information as I could and sure could use some help, ideas, anything!
I know I got the engine hot but I don't think I damaged the head gasket and all that nonsense because why does the temp. go back down once in a while. I am not loosing any coolant and the engine sounds pretty darn good but just seems to be running 15-20 degrees hotter than it did before on trailer. thanks, Tom
