Not getting gas help
R
Robert
Guest
" this motor is a 1984 15 HP g
" this motor is a 1984 15 HP gamefisher, what part do i need to replace to make it pump fuel ? It run's great as long as i keep pumping the fuel bulb... Thank's in advance "
" best p0lace to start is the
" best p0lace to start is the carb. Clean out the bowl, jet, and remove all varnish. "
Robert if it runs great while
Robert if it runs great while you pump the fuel bulb I'd try looking for a air leak in the fuel lines or bulb itself.Good luck. Ed.
