I have a 1986 70hp Evinrude outboard. It has been struggling for a while in the 2000-3000 rpm range, and recently I seem to have lost some cylinders. Here is what I have done:
- Checked spark with spark tester and all cylinders have spark
- Removed spark plug wires 1 at a time. Only the middle cylinder seems to have any effect. The bottom one definitely doesn't. I couldn't quite tell with the top.
- Tested compression: 145, 139, 135. Seems good.
- Checked ignition coil and sensor with ohmeter as much as I could without specialized equipment.
- Confirmed that there is no gooey stuff dripping down from stator.
- Tested resistance of spark plug wires. All are good.
- Replaced and gapped all spark plugs.
- Rebuilt all 3 carburetors.
- Replaced fuel pump, fuel separator, fuel filter, parts of fuel line.
Engine runs, but clearly not on all cylinders, and requires a lot of choke. Any ideas what could be the problem?
