scott_duerring
What is considered a "normal" vacuum gauge reading for an 8.2 MPI Crusader engine? Both of mine read 14-15 at idle with the gauge plugged into manifold outlet for the fuel regulator.
As long as it is consistent (steady) I'd say you are at the low side of ok (GM service data says 15-20 in Hg at ECU set idle )...
Which ECU do you have? The newer ones have a diagnostic called a cylinder power balance test that will quickly point you down that path (ID the "problem cylinder")... a leakdown test may still be needed for additional insight.
