Hi guys my motor is a 96 75hp 3cyl two stroke merc. I changed the oil in the lower unit and ran it with muffs on so I could adjust the shift cable, while it was running I noticed I could here the gears working inside the casing there was no clunking or banging or even grinding but it did seem like it was loud. It may be I,ve just not noticed this before its a new motor to me. The prop has no more than 1/8th inch of travel maybe even less, and the gear oil is fine, should I be worried everything seems to run out fine Thanks
