ridgerunner6363
"I JUST GOT MY FIRST BOAT LAST
"I JUST GOT MY FIRST BOAT LAST WEEKEND. IT'S A 24 FT PONTOON WITH A 1977 MERCURY 700 (70 HP). WHEN I GOT HOME I HOOKED UP THE HOSE TO THE FLUSHER AND CRANK THE BOAT AND IT RAN GREAT! WATER WAS PUMPING OUT THE "PEE" HOLE, AND EVERYTHING SEEMED FINE! LATER ON I CRUNK IT AGAIN, BUT I FORGOT TO TURN THE WATER BACK ON. I REALIZED THIS AFTER ONLY MAYBE A MINUTE AND I SHUT THE BOAT OFF. I WAITED A WHILE, HOOKED UP THE WATER AND CRUNK IT AGAIN, BUT I NOTICED NO WATER WAS RUNNING OUT OF THE PEE HOLE. I TOOK THE VENTS OFF THE SIDE WHERE THE WATER GOES IN AND THERE WAS BIG CHUNKS OF RUBBER IN THEM. AFTER SOME RESEARCH I FOUND OUT IT WAS THE WATER PUMP IMPELLER. I WENT TODAY AND GOT THE WHOLE KIT AND PUT IT IN. I WAS VERY CAREFUL WITH EVERYTHING, I EVEN MADE SURE THE IMPELLER BLADES WERE TURNING THE RIGHT DIRECTION. BUT WHEN I GOT IT BACK TOGETHER, I STILL HAVE THE SAME PROBLEM! NO WATER! I THOUGHT MAYBE THE PIECES OF RUBBER WERE JUST STOPPING UP THE TUBE, BUT I STUCK A WIRE IN IT, AND IT SEEMS TO BE CLEAR. I EVEN BLEW IN IT AND EVERYTHING SEEMED TO BE CLEAR. I HAVE RUN OUT OF THINGS TO TRY! ANY HELP WOULD BE GREATLY APPRECIATED! THE KIDS WERE REALLY LOOKING FORWARD TO GOING FISHING THIS WEEKEND, SO I AM HOPING TO HAVE IT FIXED! I THOUGHT MAYBE THE IMPELLER IS TURNED THE WRONG WAY. THE GUY AT THE MARINE STORE TOLD ME TO BE SURE I PUT IT IN CLOCKWISE. BUT I GUESS IT DEPENDS ON WHICH WAY YOU ARE LOOKING AT IT. COULD IT BE THAT I HAVE IT IN WRONG? I TOOK IT BACK APART TWICE, AND THE IMPELLER SEEMS FINE. IF IT WAS IN WRONG WOULDN'T IT DAMAGE THE IMPELLER? ANY ADVICE? THANKS TO EVERYONE FOR YOUR TIME!"
