All,
Had both engines rebuild last winter. re-builder found heads no longer serviceable. Replaced all four.
We managed to install and plumb both engines last spring but could not test and do final setup, engines started briefly to winterize.
Mechanic swears they ran, not well but fired up.
Fast forward to now, one engine cranks but no fire, ignition tested, plenty of spark, fuel in carb, 150psi of compression. tried a shot of ether, no joy.
other engine- 60 psi compression on most cylinder, one at 120psi, suspect stuck rings or bad valve job.
Things to check- tdc on both engines, make sure distributor is not 180 degrees out.
verify firing order is correct?
What could we have missed?
Greg
Greg
