No spark
dreising
i have a 71 johnson 50 h/p mot
i have a 71 johnson 50 h/p motor .i put it away for the winter . when i got it out it had no spark at the plugs. the coiles seem to be all wright. however i do not know how to check them.
"Does it crank over OK?
Fir
First off, check all of your grounds, on the engine, including the battery ground.
Also, check for a fuse near the starter solenoid. It is in a barrel shpaed connector and looks like a normal wire connector."
Remove the spark plugs for saf
Remove the spark plugs for safety reasons. Remove the black/yellow wire from the powerpack.
Crank and test the spark. Do you have spark now?
"Joe, I pulled the black/yello
"Joe, I pulled the black/yellow wire out of the power pack on spark there. whats next?
thanks Dave"
"With the black/yellow wire re
"With the black/yellow wire removed from the powerpack and still having no spark when cranking the engine over, the usual problem is a failed powerpack."
