No spark
ineedhelp
"Hi, I have what I believe to
"Hi, I have what I believe to be an early 60's evinrude, its an 18 hoarse, and it says fastwin on it. It has an electric start which i broke the key off in, so i tried to put a new one in, i realized it wouldnt work so put the old one back in, but now I am getting no spark, even when i pull it can someone please guide me in the right direction?? Thank You."
"well,first,i would repl the i
"well,first,i would repl the ign sw...but,if u want to ck ur spark,find the 2 blk wires,heading up under the flywheel area,...disc one of them,try again...."
"if u have some sort of a plug
"if u have some sort of a plug-in conn at eng,u can disc there..pull plugs,use a spark tester."
"Motor turns over fine, just g
"Motor turns over fine, just getting no spark, have never had a problem before this. Thanks for suggestions, still nothing, please keep them coming!!!"
"Yes I did, just took fly whee
"Yes I did, just took fly wheel off and one of my coils looks like it exploded, i am guessing this is the problem"
"yep..........do a good tune u
"yep..........do a good tune up o n it,...ck compression...now would be a good time to get it in good shape...if,comp is good.look at that other coil,very well,it needs to look very good,no hairline cracks,etc."
