"Model number TE60TLCEA is a 1
"Model number TE60TLCEA is a 1989 60hp Evinrude.
The only adjustable needle valve would be on the port side of the carburetors. At an idle, simply screw one in slowly, a little at a time until the engine has a tendency to die out, then back it up to where the engine runs the smoothest. Then go on to the next carburetor.
If you have no spark, this is the reason why the spark plugs are wet with fuel.
Disconnect the large RED electrical plug at the engine. Remove the spark plugs. Now, crank the engine by using a small jumper wire from the red battery cable at the starter solenoid to small 3/8" terminal nut that energizes the solenoid, (not the ground nut) and observe spark.
If you now have spark, the usual cause is a shorted ignition switch, in which case, replace the switch.
If still no spark, inspect the stator under the flywheel for cracks and any substance that may be dripping down from it upon the powerhead area. If there should be a substance leaking down from it, replace it.
Let us know what you find."
