No spark to Evinrude 70 1980
M
Mike Edwards
Guest
" Already replaced the timer b
" Already replaced the timer base, power pack, stator and we still don't have any spark. We tried to disconnect the kill wire (we think) not sure where it is located, but disconnected the brown and yellow wire that we are assuming is the kill wire. We don't know what else to do but if you have any ideas we appreciate it. Thank you "
" Mike.... Remove the s/plugs.
" Mike.... Remove the s/plugs. Disconnect the main large RED electrical connector at the engine. Crank the engine by engaging the solenoid with a small jumper (bat term of sol to small 3/8" nut). If you now have spark, either the kill switch is bad (if it exists) or the ignition switch is shorted.
Joe (30+ Years With OMC) "
