No Spark on No 2
N
nonothing
Guest
"Hi Guys,
I wonder if you wou
"Hi Guys,
I wonder if you would be able to help me out, I have a 1972 65 hp Johnson and I am getting spark to 1 and 3 but not to 2, i have swapped coils 1 and 2 around and then got no sspark on either, just 3, I pretty sure that i will have to replace a coil but what else would prevent spark. When coil was replaced as it still would not spark
thanks for your help
cheeers"
"i have the same engine with t
"i have the same engine with the same problem, im out of town for the week so i cant even work on it. im a mechanic, formerly marine, but i havent any experience on these ignition components. so im looking for the wisdom to flow from cyber space"
"hi,
I take it no-one can h
"hi,
I take it no-one can help me out with this one,
thanks anyway guys
will post results if i resolve this issue myself.
cheers"
"if you search the site, there
"if you search the site, there is a lot of reference to the ignition pak and other spark related items as i browse this site for 72 thru 75, 3 cylinders engines, i think Joe Reeves gives out alot of info on this subject for other 65HP owners. the 115 , 85, and 65 ignitions are probably tested the same way."
