fivestring
"I have been working all day t
"I have been working all day to find where my problem is to no avail.
I bought this boat last week. The seller started the motor and it started and ran very smoothly.
I got it home and began to clean up the rat's nest of wires in the battery box. I apparently disconnected something that powers the ignition system and I can not find out where it is.
I have good connections from the battery to the starter relay and the engine cranks over well. I get no spark on any of the three spark plug wire leads. I get no voltage from the white or red leads at the switch box. According to Seloc's troubleshooter, that tells me I have something wrong in the harness, ignition switch or battery.
The battery is fully charged. Every connection is clean and tight.
My questions are:
1. Are the safety, neutral and mercury switches supposed to be closed or open in the 'run' position?
2. What wires are supposed to send power to the engine ignition system when you turn the key on?
I know this is somewhat obscure but I need some ideas of where to look. I am certain it is going to be a wire off or a bad switch, etc.
Any help is appreciated."
My questions are:
