"I have a 1989 Stingray with 3
"I have a 1989 Stingray with 3.0L engine (4 cylinders). Cranks but will not start after storing for winter (ran OK last Fall). No spark coming from ignition coil. I get 12V at (+) and (-) terminals when points are open; and 6V at (+) and 0.7V at (-) when points are closed. Voltage at both terminals drops to 6 when cranking. Replaced ignition coil and still no spark. Get 12V from wire from coil (to distributor cap), so that seems OK.
There are two wires on (+) terminal: purple/yellow (from starter) and purple (resistance wire I think from alternator). There are two wires on (-) terminal: black wire (to distributor cap) and gray wire (to wiring harness). Disconnected gray wire and still no spark. Replaced points, condenser, rotor, and cap in May 2008. Points seem to be opening and closing OK (and spark). Any suggestions or help would be appreciated. Thanks."
