No spark 89 90hp rude
sticky
"hi disconnected b/y wire got
"hi disconnected b/y wire got spark,replaced ign. switch,cut off switch,still no spark with b/y wire plugged in,ran jumper wire from m on ign. to b/y wire plug,still no spark,what do you think thnx to all"
"no spark on all four,do magne
"no spark on all four,do magneto test
also try unplugging the main engine harness
(big round plug)then crank with test button
from solinoid.double check all new connectoins"
"there is def a prob with conn
"there is def a prob with connections at remote box.could also be not for sure a mechanical,
issue in the box as well ,neautral safty,so you cant start it while in gear/high rev with shift lever.
just trying to give you a little more to go on"
"yea i hear ya,im thinking som
"yea i hear ya,im thinking something in boat harness,dont have another to try,also just checked im getting volts from kill wire to pack when turn key on."
that is very bad/that will kil
that is very bad/that will kill a pack very quickly.disconnect it before you cost your self some cash.try on ohm meter on the wires/look for any cuts breaks..e.t.c...replace as needed.
you said its a new kill switch(tether cord typ)
test it as well
u have....either a bad ign sw.
u have....either a bad ign sw..wired wrong...or blk/yell wire is grounded.....it is not ur eng's fault/prob..
"thanx to all,it was the ign s
"thanx to all,it was the ign switch i had the kill wires hooked on the wrong m post i didnt know you have to have allthe kill switches on the tall m post,well thats all i did,its right now thnx again"
