No spark 1996 150 johnson
M
mark duggan
Guest
Looking for help.Had a problem
Looking for help.Had a problem starting when boat sat for a few days. But ran fine after.
Now no spark in all plugs?
Emergency lanyard connected?
Emergency lanyard connected? Water in ignition switch?
Thanks for the feedback. Is th
Thanks for the feedback. Is there a easy way to test the ignition switch?For the last 2 months if it didn't start right away. I would have to wait @10 min. then it would fire up.After that it would start right up the rest of the day?Any thoughts? thanks again for the help.
"Mark, The ignition switch kil
"Mark, The ignition switch kills the ignition. If you disconnect the black with yellow trace wire at the igniton switch, that will eliminate the ign switch from the circuit."
Thanks for everyones help.It w
Thanks for everyones help.It was the ignition switch.Replaced it and so far so good.Time to go striper fishing.
"Hi, I have a Johnson 90 (
"Hi, I have a Johnson 90 (1990)and it suddenly stopped this morning while trolling. It would not restart and I now have no spark. Any thoughts as to where to go to from here?. I live in Rarotonga and there is no mechanic here. The engine has done 300 hours mostly by me."
