Motor ran fine...starter stopped engaging...disconnected battery...replaced starter...solenoid was removed and reinstalled...apparently too close to block...battery connected...tried starting...starter gear engaged as designed...solenoid arced to block...disconnected battery and relocated solenoid further away from block...reconnected battery and starter worked fine but motor would not start. Connected spark tester and no spark to either cylinder. Have service manual and checked kill switch, neutral start switch, key switch and all checked out. Even removed black/yellow wire from UFI power pack and still no spark. So my question is can I check the power pack, charge coil, and stator from the terminal block - tried to post photo of block but was not successful. I am trying to trouble shoot without removing the flywheel. Any help is appreciated. Thanks
