Matthew Sharpless
I have a 1976 35el76g electric start with tiller handle control. I have no spark any suggestions?
1. Try disconnecting the kill switch. Make it an open circuit.
2. Check the points. If either point set fails there will be NO spark. At all.
3. Check driver coil, mag plate wiring, and feed wires to high volt coils, 2, mounted @ cylinder head.
To check for spark, spin motor, (spark plugs out) with electric starter. Be certain to provide good ground for whatever type of spark tester or spark plugs you should use.
