turbowrenchhead
Good morning and hello. I'm a new member as of today. Thursday I picked up a 15' Fiberglass starcraft and a 1968 Johnson. The seller stated that the motor did not start and it probably needed a starter and or a solenoid. I am a mechanic so I checked out the motor to make sure it wasn't a dud. You can never trust what ppl tell you, that I have learned the hard way. So I brought some tools and a compression gauge. The compression was at 105psi on both. So that was a little low but live-able. Next I checked for spark and it had it. I shot a bit of starting fluid into the carb and it started for a couple seconds. So I bought it. I took it home and pulled the starter and solenoid and took it to a rebuild shop. They said nothing was wrong with the starter so they put it back together and sold me a solenoid and charged me $25. I put the starter and solenoid back on and now had a freshly charged battery. I cranked over the engine and I had no spark. I started looking it over and I came across a wire that was disconnected and I didn't remember disconnecting it from anything. After many hours of reading and downloading a manual I now know that it was the wire coming off the side of the cut out switch and is suppose to supply the ground to the starter solenoid. Before I knew what was what. I tried connecting it to ground and then to power and I still had no spark. No combination worked, still no spark.
At this point I know that my safety switch is no good. Its always is a closed circuit. So that switch is bad. The previous owner must of had the safety switch and cut out switch bypassed because there is a wire going to the starter solenoid that has constant ground. After studying a wire diagram I tried hooking up power to the coils. Yeah the wire got warm fast. Thats not good! I pulled the flywheel and the RH side coil was warm. I ohmed checked that coil and I had .6 ohms on primary and 4000 on secondary. I would think that this is in spec but I have no parameters to go by.
So my question is how do the coils get there power. Is there battery power supplied to both points and the points control the power side?
I have two black wires coming out of the distributor but I don't know if they are suppose to both have power on them or not. Is white ground and black power??
I'm a auto and atv mechanic however this is a whole new ball game for me. I'm used to stators and cdi's. Those I have no problem diagnosing. Did I fry my coils by supplying power to the distrib? Any help would be greatly appreciated. I thought I was going to be on the water today fishing with my family. That's not happening this weekend.
