no reverse on 1996 75 hp mercury
cbelk
I recently bought a 1996 75 hp mercury outboard. when I bought it reverse was not working. I unhooked the cable and put in gear manualy
after that it seemed to work fine. I put it in the water and (of course) it would not go into revers. it makes clunking sounds and will not engage could this be a simple cable adjustment? ahead of time for any help
Re: no reverse on 75 hp mercury
Might be - cable not turning the shift rod enough to completely engage the clutch with the reverse gear (which would give you a clunking sound) - so anything from a stretched cable to faulty linkage at the powerhead OR you have a toasted clutch dog from the previous owner "granny shifting".
If the dog is toast you have to completely tear down the lower unit (or live with no reverse)....
Most likely, but could also be the linkage that the cable attaches to up at the powerhead end of thing - something could be broken or (slipped) or binding up that is not letting the shift rod fully engage.
Or it could even be a problem at the shifter (control) end.
Re: no reverse on 90 hp mercury mariner
I have a 1981 mariner motor that has no reverse in it and it has a new impeller in it and new plugs and fuel lines what would cause me not to have reverse. i have taken the cables off cause they were old.
