No Reverse 2005 15 hp Johnson
eaa
"Forward and neutral gears wor
"Forward and neutral gears work as usual, just can't move the shift lever back to reverse. No noises, nothing else unusual. Any suggestions?"
Tried shifting both when runni
Tried shifting both when running and not. Already checked for loose parts or any obvious disconnect - no luck finding a clue.
"what is model #
the next st
"what is model #
the next step,...would be to remove lower unit,and see if prob is in it,(and prop shaft needs to be spinning in order to fully engage shfiting parts)or,in upper shifting parts."
Model # J15R1S0C. Thank you f
Model # J15R1S0C. Thank you for this trouble-shooting info! Will try this later this afternoon.
"Hi again: We took the lower
"Hi again: We took the lower unit apart last night, found the problem. A small part had come loose from the "shifting fork." Shifting works now! However, can you tell us how to get the propeller shaft back in with the two ball-bearings and the spring? Is there a sleeve that keeps the bearings in while the shaft slides in or something? Thanks much for your help again!"
"ahhh yes,here comes the PITA
"ahhh yes,here comes the PITA part....
put the spring and balls in propshaft,grease them good to help retain them,inst them,in the grooves in the clutch dog....and hope one of those ball did'nt fall off,.....and if u start now,u will have it in there this time tomorrow!.
"Thanks for the PITA info! &#
"Thanks for the PITA info! (Is that "Put It Together Again??!!)
Hubby and buddy will try this tonight. Then they will try to give me more of a description of what happened to the part and I will will send to you!
They have another question too: a short round gear, one side has groove and the other side doesn't, 3 tabs/dogs on each side - which way does it go back on the shaft?? I guess when it came apart it just came all apart at once so it's hard to tell which way to put it back.
(How's that for a flaky description??!!) Thanks again for your ongoing help -"
"notches,face forward gear!and
"notches,face forward gear!and you're welcome !and the thingy,u r describing,is called a clutch dog,..and it is installed in gearcase w/the rest of the lil doohickeys,..then the shaft gets installed...."
"the reason i am curious about
"the reason i am curious about the initial failure,unless something is done to prevent it fr happening again(new parts,loose bolt,etc) it will surely happen again."
"Yes, I agree, and you are no
"Yes, I agree, and you are no doubt very wise to ask the question. Besides, if "Reverse" stopped working one does wonder which gear is next - it might not be as optional as Reverse out on the water
I passed this all on to "the boys." Hubby is good basic mechanic and buddy is a pro Chevy mechanic, so they should be able to figure it out! Will report back to get your opinion again tonight or tomorrow!"
Hi again: It may take even lo
Hi again: It may take even longer to PITA than you estimated - they already lost one of the little bearing balls!! Can you tell us what those are called exactly so we can get new ones locally?
"oh man,i hate it when that ha
"oh man,i hate it when that happens....
----------> 0316506
*BALL, Detent
PITA----PAIN IN THE ----"
"Ahhhhh - nice acronym! (
"Ahhhhh - nice acronym! (Good thing you told me!)
Thank you much for the name and part #, am on my way to be "parts runner" right now. More later -"
