77galaxy
Hello I have a 77 galaxy 120 hp mercruiser. I pulled the lower unit greased the ujoints and also replaced impeller, replaced throttle cable and upper shift cable. I started the adjustment procedures where you push the lower cable and turn the prop counterclockwise til prop engages then pull the cable while turning the prop clockwise till prop stops / engages.....it never stopped. its a new project boat and i'll almost swear it had reverse when i installed the lower unit... when you move the cable with your hand at the engine the cable is tight but it does move in/out. I need someone to point me in the right direction if possible. thanks
